Cables Direct 2m DVI-D Single Link M-M Cable
Quicklinx: CCHKWS00 Mfr#: CDL-DV06
Length: 2m
Hurry, only 1 left in stock!
£4.78 ex VAT
£5.73 inc VAT
This DVI cable is for digital connections and abbreviated as DVI-D. For use with equipment that uses either DVI-D connectors, if used with a DVI-I connector only the digital signal will pass through. Please note this will not work with analogue equipment that uses DVI-A.
Cables Direct DVI cable - 2 m
DVI cable - single link
Length
2 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
DVI cable
TMDS Links
Single link
Length
2 m
Connector
18+1 pin digital DVI (Single-Link) - male
Length: 2m
Brand: Cables Direct
