Cables Direct 1m DisplayPort to DVI-D M-M Single Link Black Cable B/Q 130
Quicklinx: C8GNWS00 Mfr#: HDHDPORT-001-1M
Length: 1m
More than 50 In Stock
£5.72 ex VAT
£6.86 inc VAT
DisplayPort is a 20 pin connector similar to HDMI but designed to replace DVI/VGA. The standard was put forward by VESA to define a new royalty free audio/video connection. Our DisplayPort to DVI adapters are the perfect solution for adapting your DisplayPort computer or graphics card to use a DVI monitor/device.
Cables Direct display cable - 1 m
Display cable
Length
1 m
Connector
DisplayPort - male
Connector (Second End)
DVI-D - male
Display cable
Length
1 m
Connector
20 pin DisplayPort - male
24+1 pin digital DVI - male
Length: 1m
Brand: Cables Direct
