Cables Direct 15cm VGA M (source) - HDMI F (display) Adaptor + Audio + USB
Quicklinx: CCHRWS00 Mfr#: NLHDMI-SVGACAB
The VGA to HDMI converter can convert the analogue signal coming from your PC into a digital HDMI signal. This allows you to plug your older laptop or desktop computer into a modern HD television.
You can not only enjoy a high definition image but also audio from the 3.5mm stereo socket. Power is provided from the included USB cable; simply plug this into your computer. No external power adapter is needed.
  • Easy to Use: Installs in seconds, does not need drivers
  • Conversion: It can convert VGA & Audio into a complete HDMI signal
  • Leaded type adapter with built-in VGA & Audio cable
  • Input: VGA Signal, 3.5mm stereo and USB power
  • Output: HDMI Signal
NEWlink - video converter - black
Video converter
1 x HDMI input - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Enclosure Colour
Video converter
1 x HDMI input - 19 pin HDMI Type A - male , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female
USB powered
- 26 cm
Enclosure Colour
