Your basket is empty
Cables Direct 0.5m HDMI M-M Ultra HD 4K x 2K 3D
Quicklinx: CCMVWS00 Mfr#: CDLHD-300A
HDMI (High Definition Multimedia Interface) is a specification that combines video and audio into a single digital interface for use with DVD players, digital television (DTV) players, set-top boxes, and other audiovisual devices.
HDMI supports standard, enhanced, or high-definition video plus standard to multi-channel surround-sound audio.
The CDLHD-300A is a gold plated HDMI male to male cable that connects a UHD device such as a Blu-Ray player to a UHD display screen.
Cables Direct Ultra - HDMI with Ethernet cable - 50 cm
Cable
American Wire Gauge (AWG)
30
Length
50 cm
Connector
HDMI - male
Connector (Second End)
HDMI - male
HDMI Ethernet Channel (HEC), Audio Return Channel (ARC), metal connector housing
Cable Type
30
Length
50 cm
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
