Cables Direct 0.25m CAT 6 UTP PVC Injected Moulded Cable Pink - B/Q 500
Quicklinx: 9PHKWS00 Mfr#: ERT-600-HP
Category 6 cable, commonly referred to as Cat-6, is a cable standard for Gigabit Ethernet and other network protocols that are backward compatible with the Category 5/5e and Category 3 cable standards. Compared with Cat-5 and Cat-5e, Cat-6 features more stringent specifications for crosstalk and system noise. The cable standard provides performance of up to 250MHz.
Cables Direct patch cable - 25 cm - pink
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wires per Cable
8 wires
Molded
Length
25 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Pink
Network Cable Type
Patch cable - CAT 6
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded
Length
25 cm
Pink
Connector
RJ-45 - male
RJ-45 - male
ETL, ISO/IEC 11801, 3P, EN 50288 - up to 250 MHz
