This Juniper Networks XFP-10G-S compatible XFP transceiver provides 10GBase-SR throughput up to 300m over multi-mode Fibre (MMF) at a wavelength of 850nm using a LC connector. Digital optical monitoring (DOM) support is also present to allow access to real-time operating parameters. Our transceiver is guaranteed to be 100% compatible with the equivalent Juniper Networks transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Juniper Networks, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
- C2G - XFP transceiver module - 10 GigE
- XFP transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-SR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 10 GigE
- Max Transfer Distance
- 300 m
- OEM Manufacturer Equivalent Part Number
- Juniper XFP-10G-S
- 1.27 cm x 6.35 cm x 0.76 cm
- 90.7 g
- Limited lifetime warranty
- Designed For
- Juniper Networks MX5; M-series M120, M120-H, M120-L, M320; MX Series MX10, MX40, MX80; MX-series MX10, MX104, MX2010, MX2020, MX240, MX40, MX480, MX5, MX80, MX960; T-series T1600, T320, T4000, T640
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-SR
- 10 GigE
- 10 Gbps
- 850 nm
- 300 m
- Digital Optical Monitoring (DOM) support
- 1 x Ethernet 10GBase-SR - LC multi-mode female x 2
- MSA
- Juniper XFP-10G-S
- 1.27 cm
- 6.35 cm
- 0.76 cm
- 90.7 g
- Limited warranty - lifetime
- Designed For
- Juniper Networks MX5 , Juniper Networks M-series M120, M120-H, M120-L, M320 , Juniper Networks MX Series MX10, MX40, MX80 , Juniper Networks MX-series MX10, MX104, MX2010, MX2020, MX240, MX40, MX480, MX5, MX80, MX960 , Juniper Networks T-series T1600, T320, T4000, T640
