Brand
C2G Velocity™ HDMI® Coupler
Quicklinx: 7B8XWS00 Mfr#: 80146
This HDMI Coupler (f/f) provides a perfect solution for extending your existing HDMI cable by allowing two shorter High or Standard Speed cables to be coupled together with no reduction in quality. Often, the length of cable you need can be miscalculated, which is only noticed once the cable is already installed. This cost-effective solution saves you time and money, meaning that you do not have to invest in longer cables to connect your devices that are further apart. The HDMI female-to-female coupler is compact and designed for minimal signal loss to provide a reliable, quality connection between two HDMI cables. PCB design safeguards signal integrity; gold-plated connectors.
  • Colour
    Blue
  • Warranty
    Lifetime
  • Connector 1
    (1) HDMI Female
  • Connector 2
    (1) HDMI Female
C2G Velocity HDMI Coupler - HDMI coupler
Cable
HDMI coupler
Blue
Connector
HDMI - female
Connector (Second End)
HDMI - female
Cable Type
HDMI coupler
Plated Connector
Gold
Blue
Connector
19 pin HDMI Type A - female
RoHS
Limited warranty - lifetime
