Achieve the required power from your cable box, DVD player, gaming console or other HDMI source device for applications involving HDMI extensions, switches, splitters or other HDMI devices that rely on the power from the HDMI output port of the source. When a device demands more current than the source device can supply, this will result in a voltage drop and subsequently a reduction in video quality. This USB Powered HDMI Voltage Inserter overcomes this problem by isolating the power from the source device and providing 5 volts and 1 amp of dedicated power to give a crisp, clean signal for high definition video up to a resolution of 1080p. Simply connect the voltage inserter directly to the source device through the HDMI port, connect the USB cable from the voltage inserter to an available USB port and a HDMI cable from the voltage inserter to other HDMI devices for a straightforward installation.
Seamless connectivity
The USB Powered HDMI Voltage Inserter from C2G offers a solution for connecting HDMI devices. With both HDMI and USB interfaces supported, it ensures a bridge between your audio/video equipment and power sources. -
High compatibility
Featuring a 19-pin HDMI Type-A female connector on one end and a dual 19-pin HDMI Type-A male plus 4-pin USB Type-A male connector on the other, this adapter is designed to fit a wide range of devices, making it a versatile addition to your tech toolkit. -
Quality
Compliant with RoHS standards and TAA-compliant, this HDMI voltage inserter ensures high-quality construction and adherence to environmental and trade regulations, ensuring reliability and performance.
- C2G USB Powered HDMI Voltage Inserter - video / audio adaptor - HDMI / USB - TAA Compliant - 1.8 m
- Cable
- Video / audio adaptor - HDMI / USB
- TAA Compliant
- Length
- 1.8 m
- Black
- Connectors
- HDMI - female
- Connectors (Second End)
- HDMI - male , USB - male
- 3-year warranty
- Cable Type
- Interface Supported
- HDMI / USB
- Length
- 1.8 m
- Black
- Connectors
- 19 pin HDMI Type A - female
- 19 pin HDMI Type A - male , 4 pin USB Type A - male
- RoHS
- TAA Compliant
- Limited warranty - 3 years
C2G USB Powered HDMI Power Inserter
