C2G USB Charging Y Cable
Quicklinx: 9Y4QWS00 Mfr#: 81709
Length: 25cm
£4.07 ex VAT
£4.88 inc VAT
The USB Charging Y Cable is the ideal solution for charging two smartphones, tablets or other mobile devices. The 30 gauge conductor construction provides the flexibility to connect in even the tightest of spaces. This flexibility and the compact size of this cable make it the ideal portable solution.
  • Connector 1
    (1) USB-A Male
  • Connector 2
    (2) USB Micro-B Male
  • Warranty
    Lifetime warranty
C2G USB Charging Y Cable - USB power cable - 25 cm
Cable
USB power cable
American Wire Gauge (AWG)
30
Length
25 cm
Connector
2 x Micro-USB Type B (power only) - male
Connector (Second End)
USB (power only) - male
Cable Type
USB power cable
30
Length
25 cm
Plated Connector
Nickel
Connector
2 x 5 pin Micro-USB Type B (power only) - male
4 pin USB Type A (power only) - male
Limited warranty - lifetime
Length: 25cm
Brand: C2G
