C2G USB Charging Cable
Quicklinx: 9Y4PWS00 Mfr#: 81708
Length: 46cm
£3.07 ex VAT
£3.68 inc VAT
The USB charging cable is the ideal solution for charging a smartphone, tablet or other mobile device. The 30 gauge conductor construction provides the flexibility to connect in even the tightest of spaces. This flexibility and the compact size of this cable make it the ideal portable solution.
  • Efficient charging
    Designed with a 30 AWG wire, this USB charging cable ensures efficient power transfer, providing a reliable charging solution for your devices.
  • Versatile connectivity
    Featuring both USB Type-A and Micro-USB Type-B connectors, this cable offers versatile compatibility, making it an essential accessory for a wide range of devices.
  • Durable design
    The nickel-plated connectors not only ensure a secure connection but also resist corrosion over time, extending the lifespan of the cable and ensuring lasting performance.
C2G USB Charging Cable - USB power cable - 46 cm
Cable
USB power cable
American Wire Gauge (AWG)
30
Length
46 cm
Connector
USB (power only) - male
Connector (Second End)
Micro-USB Type B (power only) - male
Cable Type
USB power cable
30
Length
46 cm
Plated Connector
Nickel
Connector
4 pin USB Type A (power only) - male
5 pin Micro-USB Type B (power only) - male
Limited warranty - lifetime
Length: 46cm
Brand: C2G
