When you need just a little more distance, this cable will extend the reach of your existing USB A/B cable. Foil and braid shielding reduce EMI/RFI interference and twisted pair construction helps reduce crosstalk for a high speed, error-free data transfer. USB 2.0 compatible. PC and Mac compatible.
- C2G 2m USB 2.0 A Male to A Female Extention Cable (6.6ft) - USB extension cable - USB to USB - 2 m
- Technology
- Shielded twisted pair (STP)
- EMI/RFI protection
- Length
- 2 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type A - female
- Black
- Limited lifetime warranty
- Technology
- Shielding Material
- Foil with braid
- Length
- 2 m
- Black
- 188 g
- Connector
