C2G USB Cables - A to A 2m
Quicklinx: D0F1WS00 Mfr#: 82107
£4.78 ex VAT
£5.73 inc VAT
When you need just a little more distance, this cable will extend the reach of your existing USB A/B cable. Foil and braid shielding reduce EMI/RFI interference and twisted pair construction helps reduce crosstalk for a high speed, error-free data transfer. USB 2.0 compatible. PC and Mac compatible.
  • Enhanced durability
    The foil with braid shielding material ensures the USB extension cable is robust and secure, providing long-lasting performance without signal interference.
  • Versatile connectivity
    Featuring a 4-pin USB Type-A male connector on one end and a female connector on the other, this cable extends your USB connection by 2 meters (6.6 feet), offering flexible placement of your USB devices.
  • Superior protection
    Equipped with EMI/RFI protection, the cable safeguards against external noise and interference, ensuring a clean and reliable data transmission.
C2G 2m USB 2.0 A Male to A Female Extention Cable (6.6ft) - USB extension cable - USB to USB - 2 m
USB extension cable
Shielded twisted pair (STP)
EMI/RFI protection
Length
2 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB extension cable
Shielding Material
Foil with braid
EMI/RFI protection
Length
2 m
188 g
Connector
Brand: C2G
