C2G USB Cables - A to A 1m
Quicklinx: D0DZWS00 Mfr#: 82106
Length: 1m
£4.08 ex VAT
£4.89 inc VAT
When you need just a little more distance, this cable will extend the reach of your existing USB A/B cable. Foil and braid shielding reduce EMI/RFI interference and twisted pair construction helps reduce crosstalk for a high speed, error-free data transfer. USB 2.0 compatible. PC and Mac compatible.
  • Enhanced connectivity
    The 1m USB 2.0 A Male to A Female Extension Cable extends the reach of your USB devices, making it easier to connect printers, scanners, keyboards, and other peripherals to your computer without compromising on signal quality.
  • Robust protection
    Equipped with EMI/RFI protection, this cable ensures that your device connections are not only extended but also protected against electromagnetic and radio frequency interference, maintaining signal integrity and reliability.
  • Durable design
    Featuring a shielding material of foil with braid, the cable offers superior durability and minimizes signal loss, ensuring a stable and secure connection for all your devices.
C2G 1m USB 2.0 A Male to A Female Extention Cable (3.3ft) - USB extension cable - USB to USB - 1 m
USB extension cable
Shielded twisted pair (STP)
EMI/RFI protection
Length
1 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB extension cable
Shielding Material
Foil with braid
EMI/RFI protection
Length
1 m
100 g
Connector
Length: 1m
Brand: C2G
