C2G USB C to USB Adapter - SuperSpeed USB - 5Gbps - F/M - USB-C adapter - USB-C to USB Type A
Quicklinx: G6WLWS00 Mfr#: 54427
Length: [N/A]
£9.02 ex VAT
£10.82 inc VAT
This USB-C Female to USB-A Male SuperSpeed USB 5Gbps Adapter Converter is the perfect solution for connecting a USB-C device to a laptop or desktop computer that does not have a USB-C port.
Simply connect the adapter converter into a USB-A port of a laptop or desktop computer and enjoy plug and play connectivity for USB-C devices. This adapter converter supports a data rate up to 5Gbps for data transfer and 900mA of power for device operation and charging. This adapter converter is compatible with earlier USB versions.
The USB-C connector has a symmetrical design which is identical on both sides, so no more worrying about whether it's upside-down or right-side-up. It will plug in the first time, every time - while preventing damage to the connector port from frequent plugging and unplugging.
  • Effortless connectivity
    The USB C to USB Adapter bridges the gap between USB-C and USB-A devices, offering a seamless connection that enhances your workflow without the need for additional drivers or software. Its Plug-and-Play compliance ensures a hassle-free setup, allowing you to connect devices quickly and efficiently.
  • Durable design
    Crafted with a PVC jacket and molded cable features, this adapter is built for durability and long-term use. The robust construction protects against wear and tear, ensuring your adapter remains reliable over time.
  • High-speed data transfer
    Experience swift data transfer speeds of up to 5 Gbps with the SuperSpeed USB Adapter. This feature allows for quick and efficient file transfers, reducing wait times and improving productivity.
C2G USB C to USB Adapter - SuperSpeed USB Adapter - 5Gbps - F/M - USB-C adapter - 24 pin USB-C to USB Type A
USB-C adapter
Molded
Connector
24 pin USB-C - female - reversible
Connector (Second End)
9 pin USB Type A - male
USB 3.0
USB-C adapter
Jacket Material
PVC
Molded
8.62 g
Connector
USB 3.0, Plug and Play
Length: [N/A]
Brand: C2G
