Experience 4K ULTRA HD displays and fast charging with this USB-C to HDMI Audio/Video adapter converter with power delivery which allows you to connect a device with a USB 3.1 Type C connector, such as a Chromebook, laptop or tablet, to an HDTV, projector or other HDMI-equipped display for audio and video, whilst simultaneously charging the source device. This adapter utilises the audio/video support built into the USB Type-C port to feed an audio/video signal to an HDTV or other HDMI display to achieve high-quality, 4K (ULTRA HD) video image. With delivery of up to 60 W of charging power to the connected device, this adapter converter offers a lightweight, portable and simple way to deliver video and stay charged up - whether you are out and about presenting, hot-desking or at home streaming movies. Additionally, the USB-C connector has a symmetrical design which is identical on both sides - it will plug in the first time, every time, whilst preventing damage to the connector port. The colour-coded USB Type C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables, which may support a different feature set.
Black -
Warranty
3 Years -
Connector A -1
USB-C Male -
Connector B -1
HDMI Female -
Connector B -2
USB-C Female
- C2G USB C to HDMI Audio/Video Adapter w/ Power Delivery - USB Type C to HDMI Black - external video adapter - black
- External video adapter
- Bus Type
- USB-C
- Max Resolution
- 3840 x 2160
- Interfaces Details
- HDMI (female connector) , USB-C (female connector) , USB-C (male connector)
- Enclosure Colour
- Black
- 3-year warranty
- Bus Type
- USB-C
- Max Resolution
- 3840 x 2160 at 30 Hz
- Plug and Play
- 31 g
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 0 °C
- 50 °C
- 15 - 85% (non-condensing)
