The USB-C to Gigabit Ethernet Network Adapter is an ideal solution for converting an existing USB Type-C port on your laptop, Chromebook, tablet or other USB-C enabled device to a RJ45 Gigabit Ethernet port for a wired network connection to the Internet. This adapter utilises the high bandwidth of the USB-C port to support true Gigabit Ethernet speeds. This flexible solution requires no external power supply - simply connect the adapter to an available USB-C port, and connect a Cat5 cable from the adapter to an RJ45 Network port for a straightforward installation. Additionally, the USB-C connector has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in first time, every time, whilst preventing damage to the port. With speeds up to 1000Mbps, file transfer between computers is fast and easy, even with very large files or large amounts of multimedia data. The adapter is a great solution for more modern computers that do not provide a wired Ethernet port or have a damaged Ethernet port.
Seamless connectivity
Experience a stable and fast network connection with the USB C to Ethernet Network Adapter. This adapter ensures a seamless transition from wireless to wired networking, offering a reliable link for data-intensive tasks. -
Versatile compatibility
Designed to work effortlessly with both Mac and PC, this adapter offers broad compatibility. Its Plug-and-Play functionality makes it an ideal choice for various operating systems without the need for additional drivers. -
High-speed data transfer
With support for data transfer rates up to 1,000 Mbps, this adapter is equipped to handle high-bandwidth activities such as streaming, gaming, and large file transfers, ensuring a smooth and efficient network experience.
- C2G USB C to Ethernet Network Adapter - USB Type C to Gigabit Ethernet Adapter - network adapter - USB 3.0 - Gigabit Ethernet x 1
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- Ports
- 2.34 cm x 7.66 cm x 1.56 cm
- 27.8 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1000 Mbps
- USB 3.1
- Black
- System Requirements
- Apple MacOS, Microsoft Windows 7 / 8 / 8.1
- 3-year warranty
- Network adapter
- Form Factor
- External
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 1000 Mbps
- USB powered, plastic housing
- USB 3.1
- 1 x 1000Base-T - RJ-45
- Cables Included
- 1 x USB-C cable (integrated) - 6.1 cm
- FCC, RoHS
- Black
- OS Required
- 2.34 cm
- 7.66 cm
- 1.56 cm
- 27.8 g
- Limited warranty - 3 years
- 10 °C
- 40 °C
