C2G USB C to DisplayPort Adapter Converter 4K - White
Quicklinx: C17PWS00 Mfr#: 80520
Colours:
Hurry, only 2 left in stock!
£21.34 ex VAT
£25.60 inc VAT
Experience 4K ULTRA HD displays with this USB-C to DisplayPort Adapter Converter which allows you to connect the USB Type-C port of a laptop, Chromebook, tablet or other source device to the DisplayPort input of a monitor, projector or HDTV - making it an ideal solution for showing presentations, pictures or other audio/video content. This adapter supports up to a 4K (3840x2160 at 30Hz) resolution, allowing it to deliver high-quality, ULTRA HD video image to the connected display. The compact design of this adapter makes it a perfect pair for BYOD (Bring Your Own Device) applications in education or corporate environments. The USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. Pairing this device with the USB-C to VGA adapter or the USB-C to HDMI adapter provides you with a video port for any situation whilst presenting.
  • Seamless connectivity
    The USB C to DisplayPort Adapter Converter offers a smooth and effortless connection between your PC and display devices. With USB 3.1 interface, this external video adapter ensures high-speed data transmission and optimal performance.
  • High-definition visuals
    Experience stunning, high-resolution visuals up to 3840 x 2160 with the adapter's support for DisplayPort video output. Whether for work presentations or streaming, enjoy crisp, vivid images without compromise.
  • Wide temperature range
    Designed to operate within a broad temperature range, from 0°C to 50°C, this adapter ensures reliability and performance under various environmental conditions. Ideal for both indoor and outdoor use, it adapts to your needs.
  • Plug-and-play convenience
    With compliance to Plug-and-Play standards, this adapter simplifies setup by eliminating the need for additional drivers or software. It's ready to use right out of the box, making it perfect for quick and easy connections.
C2G USB C to DisplayPort Adapter Converter - USB Type C to DisplayPort White - external video adapter - white
External video adapter
Bus Type
USB 3.1
Max Resolution
3840 x 2160
Interfaces Details
DisplayPort , USB 3.1 (USB-C)
Enclosure Colour
White
3-year warranty
Bus Type
USB 3.1
Max Resolution
3840 x 2160 at 30 Hz
Interfaces Details
HDCP
Plug and Play
33 g
Enclosure Colour
White
Limited warranty - 3 years
50 °C
Brand: C2G
