C2G USB-C Ethernet and 3-Port USB Hub - White
Quicklinx: DWMXWS00 Mfr#: 82409
Wired / Wireless: Wired
Protocol: Ethernet, Gigabit Ethernet, Fast Ethernet
Form Factor: External
Type: Network adapter
Colours:
£30.24 ex VAT
£36.28 inc VAT
The USB-C to Ethernet Adapter with 3-Port Hub is an ideal solution for wired network connectivity and data transfer on the go, in the office, or any work space. This adapter connects to a USB-C or Thunderbolt 3 enabled laptop, tablet, or desktop computer and features an Ethernet port and three USB 3.0 ports. The small form factor of this adapter makes it a portable and convenient solution that provides a Gigabit Ethernet port for a wired internet connection and three USB 3.0 ports to connect peripheral devices. The adapter is perfect for connecting to networks where Wi-Fi is unavailable or for computers that do not provide a wired Ethernet port or possibly have a damaged Ethernet port. The Ethernet port allows for reliable internet connectivity and file transfer speeds up to 1000Mbps, whilst the three USB 3.0 ports enable transfer speeds up to 5Gbps.
  • Efficient connectivity
    The C2G USB C Ethernet and 3 Port USB Hub White offers a seamless connection to Ethernet networks with a data transfer rate of 1 Gbps, ensuring fast and reliable Internet access for all your needs.
  • Enhanced expansion
    With a built-in 3-port SuperSpeed USB 3.0 hub, this device expands your computer's connectivity, allowing for additional peripherals to be connected with ease.
  • Plug-and-Play convenience
    Designed for simplicity, this hub adheres to Plug-and-Play standards, making it straightforward to use without the need for additional drivers or software installations.
  • Durable and compliant
    The hub is built to last, featuring an integrated USB-C cable and compliance with RoHS standards, ensuring both durability and environmental responsibility.
C2G USB C Ethernet and 3 Port USB Hub White - Hub - 3 Ports - network adapter - USB-C - Gigabit Ethernet x 1 + USB 3.0 x 3
Network adapter
External
Interface (Bus) Type
USB-C
Ports
41 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
VL813
USB 3.1
White
3-year warranty
Network adapter
External
USB-C
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
USB powered, built-in 3-port SuperSpeed USB 3.0 hub
USB 3.1
Processor / Memory
VL813
1 x 1000Base-T - RJ-45 - female , 3 x USB 3.0 - 9 pin USB Type A (power only) - female
1 x USB-C cable (integrated)
Plug and Play, RoHS
White
41 g
Limited warranty - 3 years
45 °C
Protocol: Ethernet
Protocol: Gigabit Ethernet
Protocol: Fast Ethernet
Brand: C2G
