The USB-C to Ethernet Adapter with 3-Port Hub is an ideal solution for wired network connectivity and data transfer on the go, in the office, or any work space. This adapter connects to a USB-C or Thunderbolt 3 enabled laptop, tablet, or desktop computer and features an Ethernet port and three USB 3.0 ports. The small form factor of this adapter makes it a portable and convenient solution that provides a Gigabit Ethernet port for a wired internet connection and three USB 3.0 ports to connect peripheral devices. The adapter is perfect for connecting to networks where Wi-Fi is unavailable or for computers that do not provide a wired Ethernet port or possibly have a damaged Ethernet port. The Ethernet port allows for reliable internet connectivity and file transfer speeds up to 1000Mbps, whilst the three USB 3.0 ports enable transfer speeds up to 5Gbps.
Seamless connectivity
Experience the convenience of expanding your single USB-C port into an Ethernet port and three USB 3.0 ports. This hub is designed to ensure a stable, wired Internet connection with a data transfer rate of 1 Gbps, alongside high-speed connectivity for your USB devices. -
Effortless integration
Thanks to its Plug-and-Play compliance and RoHS standards adherence, this hub integrates smoothly into your setup without the need for additional drivers or software. Its external form factor and integrated USB-C cable offer a compact and portable solution for your connectivity needs. -
Durable and reliable
Constructed to withstand the rigors of daily use, this hub operates efficiently within a wide temperature range from 0°C to 45°C. Its robust design ensures reliable performance, whether at home, in the office, or on-the-go.
 - C2G USB C Ethernet and 3 Port USB Hub Black - Hub - 3 Ports - network adapter - USB-C - Gigabit Ethernet x 1 + USB 3.0 x 3
 - Network adapter
- Form Factor
 - External
- Interface (Bus) Type
 - USB-C
- Ports
 - 41 g
- Cabling Type
 - Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
 - 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
 - 1 Gbps
- Processor
 - VL813
 - USB 3.1
 - Black
 - 3-year warranty
 - Network adapter
- Form Factor
 - External
 - USB-C
- Ports
- Connectivity Technology
 - Wired
- Cabling Type
 - 1 Gbps
 - USB powered, built-in 3-port SuperSpeed USB 3.0 hub
 - USB 3.1
Processor / Memory
- Processor
 - VL813
 - 1 x 1000Base-T - RJ-45 - female , 3 x USB 3.0 - 9 pin USB Type A (power only) - female
- Cables Included
 - 1 x USB-C cable (integrated)
 - Plug and Play, RoHS
 - Black
 - 41 g
 - Limited warranty - 3 years
 - 0 °C
 - 45 °C
