C2G USB C Ethernet and 3 Port USB Hub - Black
Quicklinx: DWMPWS00 Mfr#: 82406
Wired / Wireless: Wired
Protocol: Gigabit Ethernet, Fast Ethernet, Ethernet
Form Factor: External
Compatibility: [N/A]
Type: Network adapter
Colours:
Hurry, only 1 left in stock!
£26.25 ex VAT
£31.50 inc VAT
The USB-C to Ethernet Adapter with 3-Port Hub is an ideal solution for wired network connectivity and data transfer on the go, in the office, or any work space. This adapter connects to a USB-C or Thunderbolt 3 enabled laptop, tablet, or desktop computer and features an Ethernet port and three USB 3.0 ports. The small form factor of this adapter makes it a portable and convenient solution that provides a Gigabit Ethernet port for a wired internet connection and three USB 3.0 ports to connect peripheral devices. The adapter is perfect for connecting to networks where Wi-Fi is unavailable or for computers that do not provide a wired Ethernet port or possibly have a damaged Ethernet port. The Ethernet port allows for reliable internet connectivity and file transfer speeds up to 1000Mbps, whilst the three USB 3.0 ports enable transfer speeds up to 5Gbps.
  • Seamless connectivity
    Experience the convenience of expanding your single USB-C port into an Ethernet port and three USB 3.0 ports. This hub is designed to ensure a stable, wired Internet connection with a data transfer rate of 1 Gbps, alongside high-speed connectivity for your USB devices.
  • Effortless integration
    Thanks to its Plug-and-Play compliance and RoHS standards adherence, this hub integrates smoothly into your setup without the need for additional drivers or software. Its external form factor and integrated USB-C cable offer a compact and portable solution for your connectivity needs.
  • Durable and reliable
    Constructed to withstand the rigors of daily use, this hub operates efficiently within a wide temperature range from 0°C to 45°C. Its robust design ensures reliable performance, whether at home, in the office, or on-the-go.
C2G USB C Ethernet and 3 Port USB Hub Black - Hub - 3 Ports - network adapter - USB-C - Gigabit Ethernet x 1 + USB 3.0 x 3
Network adapter
External
Interface (Bus) Type
USB-C
Ports
41 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
VL813
USB 3.1
3-year warranty
Network adapter
External
USB-C
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
USB powered, built-in 3-port SuperSpeed USB 3.0 hub
USB 3.1
Processor / Memory
VL813
1 x 1000Base-T - RJ-45 - female , 3 x USB 3.0 - 9 pin USB Type A (power only) - female
1 x USB-C cable (integrated)
Plug and Play, RoHS
41 g
Limited warranty - 3 years
45 °C
Protocol: Fast Ethernet
Protocol: Ethernet
Brand: C2G
