The USB-C to Ethernet Adapter with Power Delivery is an ideal solution for wired network connectivity and data transfer on the go, in the office, or any work space whilst having the ability to simultaneously charge a mobile device. This adapter connects to a USB-C or Thunderbolt 3 enabled laptop, tablet, or desktop computer and features an Ethernet port and a USB Type-C port with power delivery. The small form factor of this adapter makes it a portable and convenient solution that provides a Gigabit Ethernet port for a wired internet connection and a USB Type-C port with power delivery. The adapter is perfect for connecting to networks where Wi-Fi is unavailable or for computers that do not provide a wired Ethernet port or possibly have a damaged Ethernet port. The Ethernet port allows for reliable internet connectivity and file transfer speeds up to 1000Mbps, whilst the USB Type-C port provides up to 60W of power to connected devices.
Seamless connectivity
The USB C to Ethernet Adapter With Power Delivery - White offers a reliable wired connection to the Internet via a RJ-45 connector, supporting Ethernet, Fast Ethernet, and Gigabit Ethernet for versatile and speedy online access. -
Effortless integration
Designed with Plug-and-Play compliance and a USB 3.1 interface, this adapter ensures a hassle-free setup, allowing for immediate use without the need for additional drivers or software. -
Optimized for performance
Featuring a data transfer rate of up to 1,000 Mbps, the adapter facilitates rapid file transfers and smooth streaming, making it an ideal choice for high-speed Internet tasks. -
Durable and compliant
Constructed to meet RoHS standards, this adapter not only prioritizes your health and safety but also ensures durability and reliability for prolonged use. -
Portable power support
The adapter's USB-C power delivery support enables charging of your device while in use, ensuring you stay powered up and connected no matter where you are.
 - C2G USB C to Ethernet Adapter With Power Delivery - White - network adapter - USB-C - Gigabit Ethernet x 1
 - Network adapter
- Form Factor
 - External
- Interface (Bus) Type
 - USB-C
- Ports
 - 260 g
- Cabling Type
 - Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
 - 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
 - 1000 Mbps
- Processor
 - VL813
 - USB 3.1
 - White
 - 3-year warranty
 - Network adapter
- Form Factor
 - External
 - USB-C
- Ports
- Connectivity Technology
 - Wired
- Cabling Type
 - 1000 Mbps
 - USB powered
 - USB 3.1
Processor / Memory
- Processor
 - VL813
 - 1 x 1000Base-T - RJ-45 - female , 1 x USB-C - 24 pin USB-C (power only) - female
- Cables Included
 - 1 x USB-C cable (integrated)
 - Plug and Play, RoHS
 - White
 - 260 g
 - Limited warranty - 3 years
 - 0 °C
 - 45 °C
