C2G USB 3.1 USB C to HDMI Adapter 4K - Black
Quicklinx: CHQJWS00 Mfr#: 80512
Colours:
12 left in stock
£18.89 ex VAT
£22.66 inc VAT
Experience 4K ULTRA HD displays with this USB-C to HDMI Adapter which allows you to connect the USB Type-C port of a laptop, Chromebook, tablet or other source device to the HDMI input of a HDTV, projector or other display - making it an ideal solution for showing presentations, pictures or other audio/video content. This adapter supports up to a 4K (3840x2160 at 30Hz) resolution, allowing it to deliver high-quality, ULTRA HD video image to the connected display. The compact design of this adapter makes it a perfect pair for BYOD (Bring Your Own Device) applications in education or corporate environments. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port.
  • Seamless connectivity
    The USB 3.1 USB C to HDMI Audio/Video Adapter offers a smooth and effortless connection from your PC to HDMI-equipped monitors and projectors, enabling a high-quality video and audio experience.
  • High resolution support
    Supporting a maximum external resolution of 3840 x 2160, this adapter ensures your presentations and media are displayed in 4K clarity, making every detail sharper and more engaging.
  • Plug-and-Play convenience
    Designed with ease of use in mind, this adapter adheres to Plug-and-Play standards, requiring no additional software or drivers for installation. Simply connect and go, making it perfect for dynamic work environments and presentations on-the-go.
C2G USB 3.1 USB C to HDMI Audio/Video Adapter - USB Type C to HDMI Black - external video adapter - black
External video adapter
Bus Type
USB 3.1
Graphics Engine
- up to
Max Resolution
3840 x 2160
Interfaces Details
HDMI , USB 3.1 (USB-C)
Enclosure Colour
3-year warranty
Bus Type
USB 3.1
Max Resolution
3840 x 2160 at 30 Hz
Interfaces Details
HDCP
Plug and Play
32 g
Enclosure Colour
Limited warranty - 3 years
50 °C
Brand: C2G
Stock Status: While stocks last
Stock Status: Clearance
