The USB 3.0 to Gigabit Ethernet Network Adapter is the perfect solution for converting an existing USB 3.0 port to a Gigabit Ethernet port for connecting to a network or the Internet without replacing or adding a new network card. This adapter utilises the high bandwidth of the USB 3.0 port to support true Gigabit Ethernet speeds. This flexible solution requires no external power supply, simply connect the adapter to an available USB 3.0 port, install the included software driver and connect a Cat5 cable from the adapter to an RJ45 Network port. With speeds up to 1000Mbps, file transfer between computers is fast and easy, even with large amounts of multimedia data. The adapter works on new computers that do not provide a wired Ethernet port or legacy computers which have a damaged Ethernet port.
USB Specification
USB 3.0 -
Housing
Aluminium -
Approvals
CE compliant for RoHS2 -
Supported Operating Systems
Windows XP, 7, 8, Mac OS10.6~10.8
- C2G USB 3.0 to Gigabit Ethernet Network Adapter - network adapter - USB 3.0 - Gigabit Ethernet x 1
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- Ports
- 7.493 cm x 2.23 cm x 1.6 cm
- 84 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1000 Mbps
- System Requirements
- Apple MacOS X 10.6 - 10.8, Microsoft Windows 7 / Windows 8
- Network adapter
- Form Factor
- External
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 1000 Mbps
- 1 x 1000Base-T - RJ-45
- Cables Included
- 1 x USB cable (integrated)
- RoHS2
- OS Required
- 7.493 cm
- 2.23 cm
- 1.6 cm
- 84 g
