The Universal 4K HDMI Dongle Adapter Ring is the perfect addition to conference rooms, huddle spaces, lecture halls, or classrooms to make sure that anyone can connect. The standard configuration includes the adapters to connect nearly any device to the in-room display while supporting up to a 4K video resolution. This adapter ring includes HDMI to DisplayPort, Mini DisplayPort, or USB-C adapters to meet connectivity challenges.
Dongle Style Adapter
It can be awkward when connecting an adapter to a smaller laptop or tablet. The adapter may not line up correctly, causing the computer to shift or not set flat on the table. The dongle style adapter gives more flexibility, allowing for better placement when connecting to thin or lighter weight laptops.
Colour Coded Adapters
Each adapter is color-coded with a band that saves time and frustration by making it easy to identify the adapter you need quickly.
Integrated Pull Tab
Quickly grab the adapters when you need them with the integrated Pull Tab that is also available to be customized to feature your company or organization logo. Minimum order quantities apply to customized Pull Tabs.
Universal Cable Mount
The universal cable mount attaches directly to the in-room HDMI display cable, ensuring that the adapters are always within reach. The adapter ring slides to the HDMI connector when needed and out of the way when not in use, reducing strain on the HDMI cable and clutter on the tabletop. The optional stopper fits on HDMI cables from 5mm to 10mm in diameter and prevents the adapters from sliding too far down the cable.
Tools Included
The tools for mounting the adapters and optional stopper are in the box to simplify the installation process. The innovative HDMI Cable Gauge Tool reduces stopper installation time by allowing the right-sized stopper insert, allowing for quick identification of the HDMI cable.
Black -
Warranty
Lifetime -
Connector 1 :
(3) HDMI Female -
Connector 2 :
(1) Mini DisplayPort Male, (1) DisplayPort Male, (1) USB-C Male
 - C2G Universal 4K HDMI Dongle Adapter Ring with Color Coded Mini DisplayPort, DisplayPort, and USB-C - video adapter kit - Mini DisplayPort / DisplayPort / HDMI / USB
- Cable
 - Video adapter kit - Mini DisplayPort / DisplayPort / HDMI / USB
- Included Qty
 - 3
 - Black
 - 4K support
 - Limited lifetime warranty
- Cable Type
 - Video adapter kit 4K support
- Included Qty
 - 3
- Interface Supported
 - Adapter ring
 - Black
Details
- Included Qty x Type
 - Video adapter - Mini DisplayPort (male) to 19 pin HDMI Type A (female) , Video adapter - 20 pin DisplayPort (male) to 19 pin HDMI Type A (female) , Video adapter - 24 pin USB-C (male) to 19 pin HDMI Type A (female)
 - RoHS 2 (2011/65/EU)
 - 166 g
 - Limited warranty - lifetime
