C2G Ultra Flexible High Speed HDMI Cable with Low Profile 0.9m
Quicklinx: D0F4WS00 Mfr#: 82363
Length: 90cm
£10.53 ex VAT
£12.63 inc VAT
Experience ULTRA HD (4K) displays with this Ultra Flexible High-Speed HDMI Cable which provides a fast and reliable connection for home theatre or desktop audio video applications requiring high speed HDMI capabilities and video resolutions up to 4K (2160p). The ultra-flexible cable construction and low profile, compact connector design make this cable an ideal fit for installations in tight spaces. This High Speed HDMI Cable supports the latest HDMI features including Ultra HD, 4K at 50/60 (2160p), up to 32 audio channels and wide angle theatrical 21:9 video aspect ratio and is compatible with any modern Laptop, Chromebook, HDTV or gaming consoles, including Sony PlayStation 4 (PS4) and Microsoft Xbox ONE. This fully-functional, high bandwidth cable is tested to perform at industry standards and is backed by a lifetime warranty. Note: Both the source device and display must support a HDMI feature in order to pass that particular feature through this cable.
  • Colour
  • Specification
    HDMI features and video resolutions up to 1080p
  • Warranty
    Lifetime
  • Connector 1
    (1) HDMI Male
  • Connector 2
    (1) HDMI Male
C2G 0.9m Ultra Flexible High Speed HDMI Cable with Low Profile Connectors - HDMI with Ethernet cable - 90 cm
Cable
Length
90 cm
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K support
Cable Type
HDMI with Ethernet cable 4K support
Length
90 cm
3D-Transmission, HDMI CEC support (Consumer Electronics Control), Dolby DTS-HD support, low profile design
Connector
19 pin HDMI Type A - male
CEC
Limited warranty - lifetime
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: D0F4 044663
Condition: Customer return - item has been opened but is in excellent condition.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £1.21
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Length: 90cm
Brand: C2G
Stock Status: Used Stock
