C2G Ultima SXGA Monitor Y-cable - VGA cable - HD-15 (M) - HD-15 (F) - moulded - charcoal - 30cm
Quicklinx: 63Q2WS00 Mfr#: 81174
Type: SXGA
Length: 15m
£12.78 ex VAT
£15.33 inc VAT
The Ultima SXGA cable optimises style, quality, and value in a cable specially designed for high performance. This y-cable splits the VGA signal to provide simultaneous display of the same picture. It is constructed from 3 individually-shielded 75 Ohm coax and 4 twisted pair cable to minimize crosstalk, noise, and other EMI/RFI interference. An aluminum undermould shield assists in reducing interference to meet FCC requirements, while a 360° solder-to-connector shell and cable braid create an end-to-end shielding solution for a noise-free connection.
C2G Ultima SXGA Monitor Y-cable - VGA extension cable
VGA extension cable
Double shielded
Molded, colour-coded connectors
Connector
HD-15 (VGA) - male
Connector (Second End)
2 x HD-15 (VGA) - female
RoHS
Charcoal
VGA extension cable
Double shielded
Shielding Material
Foil with braid
Plated Connector
Gold
Charcoal
Connector
2 x 15 pin HD D-Sub (HD-15) - female
RoHS
Type: SXGA
Length: 15m
Brand: C2G
