The TruLink Gigabit USB 2.0 Ethernet Adapter is a cost-effective solution for converting an existing USB port to a 10/100/1000 Base-T Ethernet port without replacing or adding a new network card. With this adapter users can create a new network connection that allows them to connect to another network or computer without the need for a router or switch. The Auto Sensing feature detects the correct connection speed whether 10, 100 or 1000 Base-T. With speeds up to 480Mbps, file transfer between computers is fast and easy, even with large amounts of multimedia data. The adapter works on older model computers that have no Ethernet port installed, so upgrades are quick and convenient. Simply plug in the adapter and load the included software driver to get 1000 Base-T connection speeds. This flexible solution requires no external power supply.
- C2G USB to Gigabit Ethernet Adapter - network adapter
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Ports
- Gigabit Ethernet
- 91 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE
- Data Transfer Rate
- 1 Gbps
- Black
- 1 year warranty
- Network adapter
- Form Factor
- External
- USB 2.0
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- 1 x 1000Base-T - RJ-45
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Black
- Software Included
- Drivers & Utilities
- 91 g
- Limited warranty - 1 year
