C2G TruLink® DVI-D™ Splitter with HDCP™
Quicklinx: 7FYGWS00 Mfr#: 89030
Type: Splitter
Hurry, only 1 left in stock!
£57.85 ex VAT
£69.42 inc VAT
The TruLink DVI-D splitter connects two HDTV displays or two computer monitors equipped with DVI inputs. HDCP compatibility means this splitter will work with high definition video for HDTV applications and high resolution PC applications. Compatible with DVI-D equipped PC video cards operating at a maximum resolution of 1920 x 1080 pixels, or with video devices at 480p, 480i, 720p, 1080i, and 1080p scan rates. Built-in DVI repeater allows lossless runs up to 10 meters from the splitter.
C2G TruLink DVI-D Splitter with HDCP - video splitter - 2 ports
Video splitter - 2 ports
Subtype
DVI
Ports
2 x DVI
HDCP compliant
0.88 kg
1-year warranty
Enclosure Type
Desktop
Subtype
DVI
Ports
2 x DVI
Max Resolution
1920 x 1080
HDCP compliant
2 x DVI-D output , 1 x DVI-D input
External power adapter
0.88 kg
Limited warranty - 1 year
Type: Splitter
Brand: C2G
Price Range Ex VAT: 50 - 100
