The Table Mount for the Logitech Connect offers security, stability, and convenience in a clean tabletop surface mount for conference rooms, huddle spaces, or other meeting spaces. The mount can be affixed to the table with 4 tamper resistant screws or it can rest on 4 slip resistant rubber feet. The Logitech Connect is clamped into the mount with a tamper resistant screw that ensures that it will not be removed from the mount. The clamp also maintains a stable image with a vibration reduction pedestal, located directly below the Connect. Though mounted inside the clamp the Connect can still be rotated left or right to position the camera and microphone at the optimal angle. The Logitech Connect table mount is designed with 14 gauge steel that is capable of a sustained weight of 5 pounds—5 times greater than the weight of the Connect. The rubber cable grommet can channel an HDMI, USB, power cord, and lock through the mount providing strain relief to the cables to ensuring a clean installation. Note: The Logitech Connect is not included with the mount.
- C2G - mounting bracket
- Product Type
- Mounting bracket
- Placing / Mounting
- Desk mountable
- Package Content
- Table mount, band clamp sub assembly, 3 x 8-32 x 3/8" tamper resistant band clamp sub assembly screws, 4 #14 x 1/2" tamper resistant mounting screws, 4 slip resistant rubber feet, vibration reduction shim, rubber grommet, 6" touch fastener strap
- Black
- Product Material
- 14 gauge steel
- 5.485 cm x 12.011 cm x 9.208 cm
- 1.1 kg
- 1-year warranty
- Product Type
- Mounting bracket
- Desk mountable
- Product Material
- 14 gauge steel
- Package Content
- 5.485 cm
- 12.011 cm
- 9.208 cm
- 1.1 kg
- Black
- TAA Compliant
- Limited warranty: - 1 year
