Replace your overused or misplaced power cable, or just get some extra cords for convenience. This North American power cord is designed to work with most PCs, monitors, scanners, printers and other devices that use the 3-pin "Kettle Lead" shroud power connector. Plus this heavy duty 0.75mm² cord features a fully moulded design for maximum durability and long life.
Robust compatibility
Designed to connect seamlessly with PCs, this Swiss Power Cord by C2G ensures a reliable power connection for your computing devices. Its compatibility with a wide range of PC models makes it an essential accessory for your computing setup. -
High-quality connectors
Featuring a power IEC 60320 C13 connector on one end and a power SEV 1011 connector on the other, this cable is crafted for durability and a secure connection. The precise construction of the connectors ensures a stable power supply to your devices.
 - C2G Swiss Power Cord - power cable - power IEC 60320 C13 to SEV 1011 - 2 m
 - Power cable
 - Molded
- Length
 - 2 m
- Localisation
 - Switzerland
- Connector
 - Power IEC 60320 C13
- Connector (Second End)
 - Power SEV 1011 - male
 - Black
 - Limited lifetime warranty
 - Power cable
 - Molded
- Length
 - 2 m
 - Black
- Localisation
 - Switzerland
- Connector
 - RoHS, Directive 2011/65/EU
