Replace your overused or misplaced power cable, or just get some extra cords for convenience. This power cord is designed to work with laptops that use a 3-slot power cord. This 0.75mm² cord features a fully moulded design for maximum durability and long life. The female connector, often called a Clover Leaf connector, plugs directly into the device while the male connector plugs into a standard outlet.
                Versatile compatibilityDesigned specifically for PCs, this Swiss Laptop Power Cord ensures a seamless connection with a wide range of laptop models, providing reliable power delivery.
                Robust constructionFeaturing a durable power cable rated for AC 250 V, this cord is built to withstand the demands of daily use, ensuring a long-lasting power solution for your computing needs.
                Compliance assuredAdhering to Directive 2011/65/EU and RoHS standards, this power cord meets strict regulatory requirements, offering peace of mind with its compliance to safety and environmental standards.
- C2G Swiss Laptop Power Cord - power cable - IEC 60320 C5 to SEV 1011 - 2 m
- Power cable
- Molded
- Length
- 2 m
- Localisation
- Switzerland
- Connector
- Power IEC 60320 C5
- Connector (Second End)
- Power SEV 1011 - male
- Rated Voltage
- AC 250 V
- Black
- Limited lifetime warranty
- Power cable
- Rated Voltage
- AC 250 V
- Molded
- Length
- 2 m
- Black
- Localisation
- Switzerland
- Connector
- RoHS, Directive 2011/65/EU
