C2G Snap-In Blank Keystone Insert Module - White
Quicklinx: 8GZ6WS00 Mfr#: 81303
The keystone snap-in insert provide a full range of solutions for voice, home networking, home office, audio, video and more. With wide selection of snap-in modules, you can custom-configure keystone wall plates and patch panels for greater control and flexibility. Just snap in this blank insert to protect an unused port.
  • Versatile compatibility
    Designed to seamlessly integrate with PC systems, this Snap-In Blank Keystone Insert Module from C2G ensures a smooth connection with various patch panels, outlets, and components.
  • Easy installation
    The keystone type design of this modular insert allows for a straightforward snap-in setup, making it an ideal solution for efficient network configurations and upgrades.
C2G Snap-In Blank Keystone Insert Module - modular insert (blank)
Modular insert (blank)
White
Enclosure Colour
White
Cabling & Wiring
Keystone type
