This Arista Networks SFP-10G-LR compatible SFP+ transceiver provides 10GBase-LR throughput up to 10km over single-mode Fibre (SMF) at a wavelength of 1310nm using a LC connector. Digital optical monitoring (DOM) support is also present to allow access to real-time operating parameters. Our transceiver is guaranteed to be 100% compatible with the equivalent Arista Networks transceiver. This easy to install, hot swappable transceiver has been programmed, uniquely serialized and data-traffic and application tested to ensure that it will initialize and perform identically. It is built to meet or exceed the specifications of Arista Networks, as well as to comply with multi-source agreement (MSA) standards to ensure seamless network integration.
- C2G - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC single-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-LR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 1310 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 10 km
- OEM Manufacturer Equivalent Part Number
- Arista Networks SFP-10G-LR
- 1.27 cm x 5.59 cm x 0.76 cm
- 68 g
- Limited lifetime warranty
- Designed For
- P/N: A99-4HG-FLEX-TR=, ASR1000-MIP100-PR=, C8500-20X6C, C9300X-24HX-1A, FPR3105-ASA-K9, FPR3105-NGFW-K9, FPR3140-ASA-K9, FPR4215-ASA-K9, FPR4215-NGFW-K9, FPR4225-NGFW-K9, FPR4245-NGFW-K9, HCI-FI-6454-M6, N9K-C9348GC-FX3, NC57-MPA-12L-S-FC=, NCS-57C1-48Q6D-S, UCS-FI-64108-D-U, UCSX-FI-6536-NEW
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-LR
- 10GbE
- 10 Gbps
- 1310 nm
- 10 km
- Digital Optical Monitoring (DOM) support
- 1 x Ethernet 10GBase-LR - LC single-mode female x 2
- MSA
- 1.27 cm
- 5.59 cm
- 0.76 cm
- 68 g
- Limited warranty - lifetime
- Designed For
- P/N: A900-IMA8CS1Z-M=, A9903-8HG-PEC=, A99-48X10GE-1G-SE=, A99-48X10GE-1G-TR=, A99-4HG-FLEX-SE=, A99-4HG-FLEX-TR=, A9K-24P-80G-SE-B=, A9K-24P-80G-TR-B=, A9K-24X10GE-1G-CM=, A9K-24X10GE-1G-SE, A9K-24X10GE-1G-SE=, A9K-48X10GE-1G-CM=, A9K-48X10GE-1G-SE=, A9K-48X10GE-TEL-BN, A9K-MPA20X10GE-CM=, ASR1000-MIP100-PR=, C2960X-FIBER-STK, C2960X-HYBRID-STK, C8500-20X6C, C9200-NM-4X, C9300-24H-1A, C9300-24H-EDU, C9300-24U-10E, C9300-24UX-10A, C9300-24UXB-A, C9300-48H-1A, C9300-48U-10A, C9300-48UB-A, C9300-48UB-E, C9300-48UN-EDU, C9300-48UXM-A-CAP, C9300-NM-2Y, C9300X-24HX-1A, C9400-LC-24XS, C9400-SUP-1XL, C9500-16X-1A, C9500-16X-1E, C9500-16X-2Q-A, C9500-16X-2Q-E, C9500-16X-A, C9500-16X-E, C9500-16X-EDU, C9500-24X-A, C9500-24X-E, C9500-40X-10A, C9500-40X-10E, C9500-40X-1A, C9500-40X-1E, C9500-40X-2Q-E, C9500-40X-EDU, C9500-40X-P, C9500-48X-A, C9500-48X-E, CBR-DPIC-8X10G=, DN-APL-TTA-M, FPR1150-ASA-K9, FPR1150-NGFW-K9, FPR3105-ASA-K9, FPR3105-NGFW-K9, FPR3140-ASA-K9, FPR4112-ASA-K9, FPR4112-NGFW-K9, FPR4112-NGIPS-K9, FPR4115-ASA-K9, FPR4115-NGIPS-K9, FPR4125-ASA-K9, FPR4125-NGFW-K9, FPR4125-NGIPS-K9, FPR4145-ASA-K9, FPR4145-NGFW-K9, FPR4145-NGIPS-K9, FPR4215-ASA-K9, FPR4215-NGFW-K9, FPR4225-NGFW-K9, FPR4245-NGFW-K9, HCI-FI-6454-M6, HX-FI-64108, HX-FI-6454, N3K-C3264C-E, N3K-C34180YC, N3K-C3524P-XL, N3K-C3548P-XL, N3K-C36180YC-R, N9K-C92300YC, N9K-C9316D-GX, N9K-C93240YC-FX2, N9K-C9332C, N9K-C9336C-FX2, N9K-C9348GC-FX3, N9K-C93600CD-GX, N9K-C9364C-GX, N9K-X96136YC-R, N9K-X9732C-FX, N9K-X9736C-EX, N9K-X9736C-FX, N9K-X9788TC-FX, NC55-24H12F-SB=, NC55-24X100G-SB=, NC55-36X100G-SB=, NC55-36X100G-U-BA=, NC55-36X100G-U-SB=, NC-55-MOD-A=, NC55-MOD-A-BM=, NC-55-MOD-A-SE=, NC55-MOD-A-SM=, NC55-MPA-12T-S, NC55-MPA-12T-S=, NC57-MPA-12L-S-FC=, NCS4200-1T16G-PS=, NCS-5001-BUN, NCS-5002-BUN, NCS-5002-SAT1G-BUN, NCS-57C1-48Q6D-S, UCS-FI-64108, UCS-FI-64108-D-U, UCS-FI-64108-U, UCS-FI-6454, UCS-FI-6454-U, UCSX-FI-6536-NEW, WS-X45-SUP9-E
