C2G RJ45 to DB25 Male Modular Adapter - Black
Quicklinx: 686CWS00 Mfr#: 81543
Using modular adapters with inexpensive silver satin or flat oval twisted-pair wire has become a popular way to run client server applications. Many network planners have implemented modular adapters as the most cost-effective way to complete connections. Whether used in a wiring closet or throughout the office, color-coded modular adapters from C2G lend easy identification and differentiation to your cable plan. By color coding your connections, you cut down on troubleshooting time while taking full advantage of the benefits of this modular adapter approach.
  • Versatile connectivity
    The Modular Adapter by C2G offers a seamless connection between a variety of devices. With a female RJ-45 connector on one end and a male 25 pin D-Sub (DB-25) on the other, it ensures compatibility across different platforms, making it an essential tool for PC users.
  • Compliance assured
    Adhering to RoHS standards, this serial adapter not only meets regulatory compliance but also ensures a commitment to environmental sustainability. Its design and construction are aimed at reducing harmful substances, making it a responsible choice for your connectivity needs.
C2G Modular Adapter - serial adapter - RJ-45 to DB-25
Serial adapter
Connector
RJ-45 - female
Connector (Second End)
25 pin D-Sub (DB-25) - male
Serial adapter
Connector
RJ-45 - female
RoHS
