C2G RJ45 to DB15 Male Modular Adapter
Quicklinx: 6864WS00 Mfr#: 81536
Using modular adapters with inexpensive satin or flat oval twisted-pair wire has become a popular way to run client server applications. Many network planners have implemented modular adapters as the most cost-effective way to complete connections. Whether used in a wiring closet or throughout the office, color-coded modular adapters from C2G lend easy identification and differentiation to your cable plan. By color coding your connections, you cut down on troubleshooting time while taking full advantage of the benefits of this modular adapter approach.
C2G Modular Adapter - serial adapter - RJ-45 to 15 pin D-Sub (DB-15)
Serial adapter
Connector
RJ-45 - female
Connector (Second End)
15 pin D-Sub (DB-15) - male
Grey
Serial adapter
Grey
Connector
RJ-45 - female
RoHS
