C2G RapidRun[R] Multi-Format Runner Cable 7.6m
Quicklinx: 9NLJWS00 Mfr#: 87109
Length: 7.6m
£35.26 ex VAT
£42.31 inc VAT
RapidRun is designed to be the standard for in-wall audio/video installations. Using pre-terminated Break-away flying leads and wall plates with an in-wall runner ensures flexible, efficient, high quality connections for all types of equipment, with no field terminations.
RapidRun Multi-Format represents the most significant upgrade to the RapidRun cabling solution to date. With enhanced engineering that includes individually shielded pairs and an isolated ground for audio lines, this runner cable meets the rigorous demand for applications in which multiple audio/video devices are run over a single cable.
Use this CMG-rated Multi-Format runner for in-wall installations that support high-density, multi-format applications. Whether hanging a projector in a modern 21st century classroom or installing a commercial digital signage system, a clean, crisp signal will be delivered every time.
  • Efficient installation
    Designed for ease of installation, the C2G RapidRun Multi-Format Runner Cable features color-coded connectors and in-wall mounting capabilities, streamlining the setup process and ensuring a clean, professional appearance.
  • Versatile connectivity
    With female MUVI connectors on both ends, this CMG-rated cable supports versatile video and audio connections, making it an ideal solution for diverse multimedia setups.
C2G RapidRun Multi-Format Runner Cable - CMG-rated - video / audio cable - 7.6 m
Cable
Video / audio cable
Length
7.6 m
Connector
MUVI connector - female
Connector (Second End)
Colour-coded connectors, in wall mounting
Cable Type
Video / audio cable
Length
7.6 m
Connector
Limited warranty - lifetime
Length: 7.6m
Brand: C2G
