RapidRun is designed to be the standard for in-wall audio/video installations. Using pre-terminated break-away flying leads and wall plates with an in-wall runner ensures flexible, efficient, high quality connections for all types of equipment, with no field terminations.
Ideal for educational and institutional installations, this flying lead sends PC video, 3.5 mm stereo audio and RCA composite audio/video over one cable. It is commonly used on the display end of classroom setups with the corresponding wall plate used at the teacher's station.
Versatile connectivity
Equipped with VGA (HD15), 3.5mm, composite video, and stereo audio flying lead, this cable offers a comprehensive solution for transmitting both video and audio signals. Its color-coded connectors simplify the installation process, ensuring a hassle-free setup. -
High-quality construction
The shielded technology of the C2G RapidRun cable minimizes signal interference, delivering a clear and reliable audiovisual experience. Its robust design is tailored to withstand the rigors of frequent use, making it an ideal choice for both professional and home environments. -
Easy integration
Featuring male connectors on both ends, including 15 pin HD D-Sub (HD-15), RCA, and mini-phone stereo 3.5 mm, this cable seamlessly integrates with a wide range of multimedia devices. The inclusion of a MUVI connector further enhances its compatibility, offering a straightforward connection to various equipment.
- C2G RapidRun VGA (HD15) + 3.5mm + Composite Video + Stereo Audio Flying Lead - video / audio cable - VGA / composite video / audio - 50 cm
- Cable
- Video / audio cable - VGA / composite video / audio
- Technology
- Shielded
- Length
- 50 cm
- Black
- Connectors
- RCA x 3 - male , Mini-phone stereo 3.5 mm - male , HD-15 (VGA) - male
- Connectors (Second End)
- MUVI connector - male
- Colour-coded connectors
- Limited lifetime warranty
- Cable Type
- Interface Supported
- Technology
- Shielded
- Length
- 50 cm
- Black
- Connectors
- RCA x 3 - male , Mini-phone stereo 3.5 mm - male , 15 pin HD D-Sub (HD-15) - male
- RoHS
- Limited warranty - lifetime
