C2G Micro HDMI to VGA Dongle w/Power + 3.5mm
Quicklinx: D0BVWS00 Mfr#: 80509
£34.77 ex VAT
£41.72 inc VAT
This HDMI Micro to VGA and Stereo Audio Adapter Converter Dongle is an ideal solution for connecting the audio/video output of a HDMI Micro-enabled Chromebook, laptop or other source device to a VGA display and set of speakers for applications requiring high quality video resolution up to 1920x1080. Simply connect the adapter directly to the output of a Chromebook or laptop and use a standard VGA and stereo audio cable to connect to the display for straightforward installation with no signal loss. The dongle design of this adapter converter does not cause the stress on the port of a small laptop that is common when using a box style adapter.
  • Colour
  • Warranty
    Lifetime
  • Connector 1
    (1) HDMI Micro Male
  • Connector 2
    (1) VGA Female, (1) 3.5mm Stereo Female
C2G HDMI Micro to VGA and Stereo Audio Adapter Converter Dongle - video converter - black
Video converter
Max Resolution
1920 x 1080
Micro-HDMI , VGA
1 x HDMI input - 19 pin micro HDMI Type D , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm
Enclosure Colour
Video converter
Max Resolution
1920 x 1080
Micro-HDMI , VGA
38 g
Enclosure Colour
Limited warranty - lifetime
Brand: C2G
Price Range Ex VAT: 0 - 50
