This SFP (mini-GBIC) Transceiver Module is designed for use with HP network equipment and is equivalent to HP part number JD118B. This transceiver is built to meet or exceed the specifications of the OEM and to comply with Multi-Source Agreement (MSA) standards. This product is 100% functionally tested, and compatibility is guaranteed. The transceiver is hot-swappable input/output device which allows a Gigabit Ethernet port to link with a Fibre optic network. OEM specific configuration data is loaded on to the EEPROM of the transceiver at the factory, allowing this transceiver to initialize and perform identically to an OEM transceiver. This transceiver may be mixed and deployed with other OEM or third party transceivers and will deliver seamless network performance. A list of compatible network equipment is available on the Specs tab of this page. HP and the HP logo are trademarks or registered trademarks of Hewlett-Packard Development Company, L.P.. This product is not certified or endorsed by Hewlett-Packard.
- C2G - SFP (mini-GBIC) transceiver module - GigE
- SFP (mini-GBIC) transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-SX
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- GigE
- Max Transfer Distance
- 550 m
- OEM Manufacturer Equivalent Part Number
- HP JD118B
- 1.27 cm x 5.59 cm x 0.76 cm
- 68 g
- Limited lifetime warranty
- Designed For
- HP 3100, A5120, E4500; HPE 10512, 12504, 1910, 3100, 3600, 3610, 4200, 4500, 5120, 5500, 5810, 5820AF, 5830AF, 5920AF, 7506, WX5002, WX5004; FlexFabric 1.92, 11908, 12902; FlexNetwork MSR3048
- Form Factor
- Plug-in module
- Silver
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-SX
- GigE
- 1 Gbps
- 850 nm
- 550 m
- Digital Optical Monitoring (DOM) support
- 1 x Ethernet 1000Base-SX - LC multi-mode female x 2
- MSA
- HP JD118B
- 1.27 cm
- 5.59 cm
- 0.76 cm
- 68 g
- Limited warranty - lifetime
- Designed For
- HP 3100-8-PoE v2 EI Switch, A5120-24G-PoE+ SI Switch, A5120-48G SI Switch, E4500-24-PoE , HPE 10512 Switch Chassis, 12504 AC Switch Chassis, 1910-16G Switch, 1910-24G Switch, 1910-24G-PoE (170 W) Switch, 1910-24G-PoE (365 W) Switch, 1910-48G Switch, 1910-8G Switch, 1910-8G-PoE+ (180W) Switch, 1910-8G-PoE+ (65W) Switch, 3100-16 DC EI Switch, 3100-16 EI Switch, 3100-16-PoE EI Switch, 3100-24 DC EI Switch, 3100-24 EI Switch, 3100-24 V2 EI Switch, 3100-24-PoE EI Switch, 3100-24-PoE v2 EI Switch, 3100-48 Switch, 3100-8 DC EI Switch, 3100-8 EI Switch, 3100-8 v2 SI Switch, 3100-8-PoE EI Switch, 3600-24 EI Switch, 3600-24 SI Switch, 3600-24 v2 EI, 3600-24-PoE EI Switch, 3600-24-PoE SI Switch, 3600-24-PoE+ v2 EI, 3600-24-PoE+ v2 SI, 3600-24-SFP EI Switch, 3600-24-SFP v2 EI, 3600-24TP SI Switch, 3600-48 EI Switch, 3600-48 SI Switch, 3600-48-PoE EI Switch, 3600-48-PoE SI Switch, 3600-48-PoE+ v2 SI, 3610-24 Switch, 3610-24-SFP Switch, 3610-24-TP Switch, 3610-48 Switch, 4200-12G Switch, 4500-24 Switch, 4500-24-PoE Switch, 4500-48 Switch, 4500-48-PoE Switch, 5120-16G SI, 5120-24G SI, 5120-24G-PoE+ SI, 5120-48G-PoE+ EI Switch with 2 Interface Slots, 5500-24G-PoE+-4SFP HI Switch with 2 Interface Slots, 5500-24G-SFP HI Switch with 2 Interface Slots, 5500-48G-4SFP HI Switch with 2 interface Slots, 5810-48G Switch, 5820AF-24XG, 5830AF-48G Switch with 1 Interface Slot, 5830AF-96G Switch, 5920AF-24XG Switch, 7506, WX5002 Access Controller, WX5004 Access Controller , HPE FlexFabric 1.92 Tbps Type D Fabric Module, 11908-V Switch Chassis, 12902E Switch Chassis , HPE FlexNetwork MSR3048
