Product
C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black
Quicklinx: BLVFWS00 Mfr#: 80500
£14.57 ex VAT
£17.48 inc VAT
This HDMI to VGA Adapter Converter Dongle is an ideal solution for connecting the video output of a HDMI-enabled Chromebook, laptop or other source device to the VGA input port of a computer monitor or other display for applications requiring high quality video resolution up to 1920x1080. Simply connect the adapter directly to the HDMI output port of a Chromebook or laptop and use a standard VGA cable to connect to the display for straightforward installation with no signal loss. The dongle design of this adapter converter does not cause the stress on the port of a small laptop that is common when using a box style adapter.
  • Colour
  • Warranty
    3 Years
  • Connector 1
    (1) HDMI Male
  • Connector 2
    (1) VGA Female
C2G HDMI to VGA Adapter Converter Dongle - video converter - black
Video converter
Max Resolution
1920 x 1080
1 x HDMI - 19 pin HDMI Type A , 1 x VGA - 15 pin HD D-Sub (HD-15)
Enclosure Colour
Video converter
Max Resolution
1920 x 1080
44 g
Enclosure Colour
Limited warranty - lifetime
70 °C
Brand: C2G
Price Range Ex VAT: 0 - 50
