C2G HDMI to VGA Adapter - HDMI to VGA Converter - M/F - Video Converter
Quicklinx: HXMYWS00 Mfr#: 41350
£18.68 ex VAT
£22.41 inc VAT
This adapter converter dongle is an ideal solution for connecting the video output of a HDMI-enabled Chromebook or laptop to a VGA display. The dongle design of this adapter converter does not cause the stress on the port of a small laptop that is common when using a box style adapter. Up to a 1920x1080 video resolution is supported, allowing this adapter converter to meet the needs of a high performance application. Connect this adapter directly to the output of a laptop and use a VGA cable to connect to a display.
  • Seamless compatibility
    Designed to bridge the gap between HDMI and VGA interfaces, this adapter ensures seamless connectivity between your PC and VGA-equipped monitors or projectors. It's the perfect solution for utilizing older displays with modern HDMI devices.
  • High-quality video output
    Supports resolutions up to 1920 x 1080, allowing you to enjoy crisp, clear video on your VGA display. Whether it's for presentations, movies, or gaming, this converter delivers a high-definition experience without compromise.
  • Easy to use
    With no software or drivers required, setup is straightforward. Simply connect the HDMI male end to your PC and the VGA female end to your display. It's an efficient and hassle-free way to extend or mirror your screen.
C2G HDMI to VGA Adapter - HDMI to VGA Converter - M/F - video converter - black
Video converter
Graphics Engine
- up to
Max Resolution
1920 x 1080
1 x HDMI input - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Enclosure Colour
Video converter
Max Resolution
1920 x 1080
1 x HDMI input - 19 pin HDMI Type A - male , 1 x VGA output - 15 pin HD D-Sub (HD-15) - female
44 g
Enclosure Colour
Limited warranty - lifetime
70 °C
Brand: C2G
