This adapter converter dongle is an ideal solution for connecting the video output of a HDMI-enabled laptop to a DVI-D display. The dongle design of this adapter converter does not cause the stress on the port of a small laptop that is common when using a box style adapter. Up to a 1920x1200 video resolution is supported, allowing this adapter converter to meet the needs of a high performance application. Connect this adapter directly to the output of a laptop and use a DVI-D cable to connect to a display.
Seamless connectivity
Experience a hassle-free connection between your HDMI and DVI-D devices with the C2G HDMI to Single Link DVI-D Adapter Converter Dongle. This adapter ensures a reliable link between your video sources, making it ideal for various setups. -
High-quality construction
Constructed with a durable PVC jacket and aluminum mylar foil with braid shielding, this adapter is designed to resist interference and maintain the integrity of your video signal for clear and stable visuals. -
Flexible design
The compact dongle design of this adapter makes it easy to connect in tight spaces, ensuring a convenient setup without the need for extensive cabling. Its lightweight construction also makes it an ideal solution for on-the-go presentations and media sharing.
- C2G HDMI to Single Link DVI-D Adapter Converter Dongle - adapter - HDMI / DVI - 20.3 cm
- Cable
- Adapter - HDMI / DVI
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 32
- TMDS Links
- Single link
- Length
- 20.3 cm
- Black
- Connector
- DVI-D - female
- Connector (Second End)
- HDMI - male
- Limited lifetime warranty
- Cable Type
- Adapter
- Interface Supported
- HDMI / DVI
- Technology
- Double shielded
- 32
- TMDS Links
- Single link
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 20.3 cm
- Black
- Connector
- 18+1 pin digital DVI (Single-Link) - female
- 19 pin HDMI Type A - male
- Limited warranty - lifetime
