The HDMI to DisplayPort Adapter Converter allows you to connect an HDMI source device, such as your laptop or Blu-ray player, to a monitor or display with a DisplayPort input, delivering high quality video up to a maximum resolution of 1920x1200. This Converter is the perfect solution for connecting older HDMI-enabled devices that do not support a DisplayPort output to more modern, DisplayPort-equipped monitors and displays; a functionality that is not supported by other adapters that are designed to connect the DisplayPort output of a device to a display which accepts an HDMI input. Additionally, this converter supports HDCP.
- C2G HDMI to DisplayPort Converter - video converter - black
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x HDMI input - 19 pin HDMI Type A , 1 x DisplayPort - 20 pin DisplayPort
- 8.15 cm x 4.2 cm x 2.3 cm
- Enclosure Colour
- Black
- 1 year warranty
- Video converter
- Max Resolution
- 1920 x 1200
- HDCP
- Voltage Required
- AC 120/230 V (50/60 Hz)
- RoHS2
- 8.15 cm
- 4.2 cm
- 2.3 cm
- 367 g
- Enclosure Colour
- Black
- Limited warranty - 1 year
- -10 °C
- 50 °C
