C2G HDMI Over Cat5 Extender up to 50m
Quicklinx: DWKSWS00 Mfr#: 82180
£85.79 ex VAT
£102.94 inc VAT
The HDMI Over Cat5/6 Extender is ideal for extending digital video and audio, making it a great solution for digital signs, schools, churches, trade show presentations, or any application where the HDMI source is farther than 50 feet from the display. The extender can also send HDMI signals over existing Cat5 or Cat6 cable infrastructure for cost-effective reliability, while maintaining high performance quality. Convenience.
This solution is able to extend HDMI video and audio up to 164 feet and requires the use of a single Cat5 or Cat6 patch cable. With no drivers or software to install, the HDMI over Cat5/6 Extender provides total plug and play convenience. Simply connect the transmitter to the video source, the receiver to the display, and extend with a single category cable for quality video and audio. Performance.
Supporting resolutions up to 1080p at 60Hz and delivering quality sound allows the HDMI extender to meet the requirements for high performance applications and adds greater functionality to displays.
  • Colour
  • Warranty
    3 Years
  • Connector 1
    (1) HDMI Female, (1) RJ-45 Female
  • Connector 2
C2G HDMI over Cat5/6 Extender - video/audio extender - HDMI
Video/audio extender
External
Australia, United Kingdom, United States, Europe
HDMI
Transmission Medium
CAT 5/6
Max Transfer Distance
50 m
AC 120/230 V
4.9 cm x 8.45 cm x 2.4 cm
480 g
3-year warranty
External
Wired
HDMI
Max Resolution
1920 x 1080 / 1080p @ 60 Hz
50 m
Status Indicators
Power, status
1 x HDMI (input) - 19 pin HDMI Type A female , 1 x HDMI (output) - 19 pin HDMI Type A female
RoHS 2011/65/EU
Internal power supply
AC 120/230 V
4.9 cm
8.45 cm
2.4 cm
480 g
Limited warranty - 3 years
0 - 80% (non-condensing)
Brand: C2G
