C2G HDMI Over CAT5 BOX TX
Quicklinx: D0FKWS00 Mfr#: 89365
£148.40 ex VAT
£178.08 inc VAT
The HDMI over Cat5 Box Transmitter allows for the extension of an HDMI signal over solid conductor Cat5e/6 twisted pair cable up to a distance of 100 metres (330ft), without any loss or reduction in signal. This HDMI over Cat5 transmitter supports advanced HDMI features, including high definition 1080p video resolution, 3D, auto lip sync, deep colour, Dolby & DTS 7.1 audio and data transfer rates of 10.2 Gbps. This solution is compatible with any operating system and is truly plug and play with no driver or software required. In addition, this transmitter utilises TruChoice Power which provides the flexibility to power the system with a single power supply at either the transmitter or receiver end. HDBaseT technology allows the Extended Display Identification Data (EDID) signals, i.e. communication of the display’s capabilities, to pass through the extension solution ensuring that the content from the source is sent at the optimal resolution for the display. Built-in power surge protection and high ground loop immunity ensure high performance signal extension. *Stranded Cat5e/6 cables may be used for HDMI extension applications up to 75m. Shielded, solid conductor Cat5e/6 cabling is recommended for applications where the Cat5e/6 cable must be coiled, is run near other high-frequency signalling cables or in high EMI/RFI environments. Single Cat5 cable required for HDMI extension.
  • Colour
  • Warranty
    1 Year
  • Connector 1
    (1) HDMI Female
  • Connector 2
    (1) RJ-45 Female
C2G TruLink HDMI over Cat5 Box Transmitter - video/audio extender - HDMI - TAA Compliant
Video/audio extender (transmitter)
External
HDMI
Transmission Medium
CAT 5
Max Transfer Distance
100 m
11 cm x 6.5 cm x 0.9 cm
0.72 kg
TAA Compliant
3-year warranty
External
Wired
HDMI
Max Resolution
1080p
100 m
7.1 channel audio support
1 x display / video - HDMI input - 19 pin HDMI Type A female , 1 x network - RJ-45 female
1 x HDMI cable - 1.2 m
Mounting Kit
Included
FCC, RoHS
TAA Compliant
External power adapter
11 cm
6.5 cm
0.9 cm
0.72 kg
Limited warranty - 3 years
Brand: C2G
