C2G HDMI Over CAT5 BOX RX
Quicklinx: D0FLWS00 Mfr#: 89366
The HDMI over Cat5 Receiver, when paired with a transmitter, allows for the extension of an HDMI signal over solid conductor Cat5e/6 twisted pair cable up to 100m (330ft) without signal degradation at a 1080p video resolution. This solution is compatible with any operating system and is truly plug and play with no drivers or software required. In addition, this solution utilises TruChoice Power which provides the flexibility to power the system with a single power supply at either the transmitter or receiver end. HDBaseT technology allows the Extended Display Identification Data (EDID) signals, i.e. communication of the display's capabilities, to pass through the extension solution ensuring that the content from the source is sent at the optimal resolution for the display. Built-in power surge protection and high ground loop immunity ensure high performance signal extension. The HDMI over Cat5 extenders support advanced HDMI features such as 3D, auto lip sync, deep color, Dolby & DTS 7.1 audio, CEC and a 10.2 Gbps data transfer rate.
  • High-definition clarity
    The HDMI over Cat5 Box Receiver supports 1080p resolution, ensuring clear video quality for an enhanced viewing experience.
  • Extended reach
    With a maximum transfer distance of 100 m, this receiver extends HDMI signals far beyond typical limitations, making it ideal for large venues or complex setups.
  • Versatile audio support
    Equipped with 7.1 channel audio support, it delivers rich sound quality, complementing the video for a full multimedia experience.
  • Easy installation
    The inclusion of a mounting kit and its compliance with FCC and RoHS standards simplify the setup process, ensuring a hassle-free installation.
  • Reliable connectivity
    Featuring wired connectivity with HDMI and network interfaces, this receiver offers dependable video and audio extension over CAT 5 cables.
C2G TruLink HDMI over Cat5 Box Receiver - video/audio extender - HDMI - TAA Compliant
Video/audio extender (receiver)
External
HDMI
Transmission Medium
CAT 5
Max Transfer Distance
100 m
11 cm x 6.5 cm x 0.9 cm
0.54 kg
TAA Compliant
3-year warranty
External
Wired
HDMI
Max Resolution
1080p
100 m
1 x display / video - HDMI input - 19 pin HDMI Type A female , 1 x network - RJ-45 female
Mounting Kit
Included
FCC, RoHS
TAA Compliant
11 cm
6.5 cm
0.9 cm
0.54 kg
Limited warranty - 3 years
