C2G HDMI Mini to VGA Adapter Converter Dongle
Quicklinx: CHPPWS00 Mfr#: 80503
This HDMI Mini to VGA Adapter Converter Dongle is an ideal solution for connecting the video output of a HDMI Mini-enabled Chromebook, laptop or other source device to the VGA input port of a computer monitor or other display for applications requiring high quality video resolution up to 1920x1080. Simply connect the adapter directly to the output of a Chromebook or laptop and use a standard VGA cable to connect to the display for straightforward installation with no signal loss. The dongle design of this adapter converter does not cause the stress on the port of a small laptop that is common when using a box style adapter.
  • Seamless compatibility
    Designed specifically for PCs, this HDMI Mini to VGA Adapter Converter Dongle ensures a seamless connection between your computer and projector or monitor. It's the perfect solution for presentations, lectures, or even movie nights.
  • High-quality video output
    Supporting a maximum external resolution of 1920 x 1080, this dongle delivers crisp, clear video quality. Whether you're displaying detailed presentations or streaming video content, expect vivid images and excellent clarity.
  • Versatile connectivity
    Equipped with both 19-pin mini HDMI Type-C and 15-pin HD D-Sub (HD-15) connectors, this dongle offers versatile connectivity options. Easily connect to a wide range of devices without the need for multiple adapters.
C2G HDMI Mini to VGA Adapter Converter Dongle - video converter - black
Video converter
Graphics Engine
- up to
Max Resolution
1920 x 1080
Interfaces Details
Mini-HDMI , VGA
1 x HDMI input - 19 pin mini HDMI Type C , 1 x VGA output - 15 pin HD D-Sub (HD-15)
Enclosure Colour
Video converter
Max Resolution
1920 x 1080
Interfaces Details
Mini-HDMI , VGA
40 g
Enclosure Colour
Limited warranty - lifetime
