The 4X2 HDMI Matrix Switch 4K30 allows you to switch between up to four HDMI source devices in any combination on two displays, supporting high-definition video up to a resolution of 4K (2160p). The 4X2 HDMI Matrix is HDCP 1.4 compliant and supports the latest HDMI features, including 4K Ultra HD resolutions up to 3840 x 2160 at 30Hz with 4:4:4 chroma sub-sampling, 3D formats, HDMI data rates up to 10.2gbps and 12bit per channel deep colour. This Matrix Switch is compatible with Blu-ray players, gaming consoles, digital and satellite boxes and A/V receivers utilising the HDMI 1.4 standard. This product offers control and flexibility via manual push buttons located conveniently on the front of the matrix switch or by remote control over IR, allowing for quick changes between video sources. The outputs can be connected directly to displays or for longer distances they can be extended through HD BaseT. Note: HD BaseT sold separately.
- C2G 4X2 HDMI Matrix Switch 4K30 - video/audio switch - 6 ports
- Video/audio switch - 6 ports
- Subtype
- HDMI
- Ports
- 6 x HDMI
- HDCP compliant
- 11 cm x 26 cm x 2.5 cm
- 854 g
- Black
- Localisation
- United Kingdom, Europe
- 3-year warranty
- Enclosure Type
- Desktop
- Subtype
- HDMI
- Ports
- 6 x HDMI
- Max Resolution
- 3840 x 2160
- Max Video Bandwidth
- 340 MHz
- HDCP compliant
- 4 x HDMI input Type A , 2 x HDMI output Type A
- Power Device
- External power adapter
- Black
- Included Accessories
- Remote control
- HDCP 1.4
- Localisation
- 11 cm
- 26 cm
- 2.5 cm
- 854 g
- Limited warranty - 3 years
- 0 °C
- 70 °C
- 10 - 85% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 80 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
