The dual Serial ATA power splitter from C2G enables you to connect your high speed Serial ATA drives to your power chain with this 4 pin Molex to dual 15 pin Serial ATA power adapter. This power connector can be used with both 3.5" and 2.5" Serial ATA devices.
- C2G Serial ATA (SATA) Dual Power Splitter Cable - power splitter - 4 PIN internal power to SATA power - 15 cm
- Power splitter
- Length
- 15 cm
- Connector
- 4 PIN internal power - male
- Connector (Second End)
- 2 x 15 pin Serial ATA power - male
- Black
- Limited lifetime warranty
- Power splitter
- Length
- 15 cm
- Black
- Connector
- RoHS
