C2G Down Adapter HDMI adapter HDMI (M) to HDMI (F) Black
Quicklinx: CJPVWS00 Mfr#: 80562
£7.46 ex VAT
£8.95 inc VAT
This HDMI Male to HDMI Female 90° Adapter is the perfect solution for flat panel installations where space is crucial. Often there is not much clearance to fit the HDMI cable connector in the space between the flat panel and the wall. An additional problem is that the weight of the HDMI cable stresses the HDMI connector. Over time, this stress and the constant plugging and unplugging of cables can cause the HDMI connectors on your HD devices to wear down, become damaged, and even degrade picture quality. Solve both problems and protect your investment with this compact right-angle port saver. This adapter is angled to 90degrees to enable connections in a tight area. Alleviating stress from the HDMI connector, it can also absorb the abuse of repeated plugging and unplugging, therefore protecting HDMI connectors and ensuring the delivery of high quality picture over long periods of time. This compact HDMI adapter is a quick and easy way to extend the life of your valuable equipment.
  • Effortless connectivity
    The 90° Down Adapter by C2G simplifies your AV setup by offering a seamless connection between devices. Its 90° angled connector design ensures an easy fit in tight spaces, preventing cable strain and port damage.
  • High-quality construction
    Crafted with durability in mind, this HDMI adapter features a robust 19-pin HDMI Type-A male connector on one end and a female connector on the other, ensuring a secure and stable connection for optimal signal transmission.
C2G 90° Down Adapter - HDMI adapter
Cable
HDMI adapter
Connector
HDMI - male
Connector (Second End)
HDMI - female
90° connector
Cable Type
HDMI adapter 90° connector
Connector
19 pin HDMI Type A - male
19 pin HDMI Type A - female
Limited warranty - lifetime
Brand: C2G
